1 - 7 of 7 Posts
Life is settling down and it is time to get some maintenance done. Trans and rear fluids have been replaced last 25k. Plugs done last 12k. I know I need to replace front diff and transfer fluid, brake and radiator fluid. What else should I look at doing? What about timing chain or other main components? I plan on driving this truck for a long time And I want it to last. The maintenance schedule doesn't exactly go up to the miles I have to follow.
Discussion Starter · #2 ·
So no one has high miles for suggested maintenance?
Check tranny cooling hoses for leaks. I did all fluids @ 60,000, and the x-fer case fluid was real dark. All other fluids looked pretty good.
2nd guessing.
Greetings, I think the idea of checking tranny cooling lines is a good one. When I did my exaust manifolds I asked the service adviser at ed hicks nissan what I should look out for and he was'nt much help either,My truck had 89900 on it when they did the service, it's got101000 onit now. I mentioned the timing belt but he kind of shrugged and said do'nt do it till it breaks! not sure I understand his reasoning I try to be proactive when it comes to my truck but Iam also a frim believer in IF IT IS'NT BROKE DO'NT FIX IT .Do your plugs and your fluids, look for oil leaks and be glad the newer trucks are less to maintain. ( hope so inyour case anyway)
I used a turkey baster to pull out power steering fluid on a couple of different occasions, recently, (more or less a couple of partial drain and fills) and refilled it with Matic D, the same stuff I use in my transfer case.
If you just did a transmission drain and fill, [some dealers only do this too], you should do that again because only about 33% of the fluid would be new. (system is about 12 quarts and pan drains out about 4 quarts). To find the exact amount to add back in dumped the oil drain pan's contents by funnel, into pre-marked (with a permanent marker), plastic milk jugs, one marked for 1 gallon, (4 quarts), and the other in 1/2 cup increments. [I use water and a kitchen funnel when marking the jugs, before going out].
Here's how much new fluid you should have after each drain and fill if you are using that method. I've rounded the total capacity to 12 qt. and the pan to 4 qt. (the last couple of times I got out an extra cup or so, and added an equal amount of new fluid back in), but I've basically drained 1/3 of the total capacity each time, and wanted to do this over a period of 6 months or so, before the new stuff becomes old.
  • 1st change: drained 4 qt old; added 4 qt new.
    Titan had 67% old and 33% new, (4 qt of 12 were new).
  • 2nd change: drained 4 qt (2.68 qt old, 1.32 qt newish); added 4 qt new.
    Titan had 44% old and 56% new, (6.68 qt of 12 were new).
  • 3rd change: drained 4 qt (1.76 qt old, 2.24 qt newish); added 4 qt new.
    Titan had 30% old and 70% new, (8.44 qt of 12 were new).
  • 4th change: drain 4 qt (1.2 qt old, 2.8 qt newish); add 4 qt new.
    Titan has 20% old and 80% new, (9.64 qt of 12 are new).
  • 5th change: drain 4 qt (0.8 qt old, 3.2 qt newish); add 4 qt new.
    Titan will have 13% old and 87% new, (10.44 qt of 12 will be new).
After the 5th change I'll probably just do it at every other motor oil change, and not worry about the percentage.
You don't have to change it because you don't have a timing belt. It's a chain. In fact, it's 2 timing chains...one per bank. The fact that your dealer didn't know that would sent me elsewhere...FAST!
Thanks for the info/lesson,YOU right about the dealer not much to pick from round here,only one other and their 50 miles or better ,San anton is 2 hr's
1 - 7 of 7 Posts
