i have a 2006 nissan titan se tonight we replaced the crank shaft position sensor. while hooking the battery back up the fusible link threw a spark and now NO CRANK, NO START. there are no dash lights either but the remote will lock and unlock the doors and make the head lights flash. Please if anyone can help.
You can check the wires at the crank shaft sensor to make sure they are not pinched or damaged. If a damaged wire was touching metal when you reconnected the battery it could have caused a fuse to blow.
