I have a 2007 Titan. I had a trans cooling hose leak that I repaired. Now I have no overdrive and setting code P0717 Input/Turbine Speed Sensor A Circuit. The trans shifts kinda hard sometimes but mostly I don't have O/D anymore and the manual shift does nothing when I press the button. I have read that the sensor is located inside the valve body but I have also found reference to the sensor being outside the transmission. Can someone help point me in the right direction please. Thanks in advance for your help.
