2017 Titan SV, 2 wheel drive, no front CV joints,100K miles. Popping sound in front end when turning at no or low speeds. Sounds like metal on metal. Possible control rods? Anyone have this same issue?
Wheel bearings. Replaced on every titan i have owned a few times. Dont replace stock . Use timkens
Must be a Nissan Thing. Wife's Frontier ATE Wheel Bearings
I agree with the Timkens. Also, be careful removing them so as not to damage the sensor cable. I did these a few times and needed the old sensor cable once due to a bonehead drop of the bearing on install... Also, it does take a little bit sometimes for the slip/abs light to go out after installing them. Not sure if it has to sync back up. Light wasn't on before...
