1 - 7 of 7 Posts
If I have the big tow package on my 07 4x4 do I have the Dana 3.357:1 axle?
If this is true is there a specific Tru trac I should order for my Titan? Also best place and price to purchase the tru trac?
thanks
P.S Do you disable the E-lock when installing the tru trac as you would not need it?
We have a modified Dana differential. You will have to order a Titan specific Tru-Trac. The gear ratio makes no difference; you use your existing ring gear and pinion.
Thanks 38 what about the e-lock do you still use it when needed or disable it?
The e-lock will be removed when you install the Tru-Trac.
Completely removed or just no longer does anything? If completely removed what do you put in place of the hole that the e-lock occupied?
Since the entire carrier is replaced the e-lock mechanism is no longer installed. The servo stays in the hole in the differential housing.
Thanks again 38 thats great info.
1 - 7 of 7 Posts
