1 - 20 of 20 Posts
With a 4x4 I don't think you have an issue, but don't quote me on that I know the 4x4s sot higher. I was wondering the same thing, but a 2010 2wd SE.
Oh , it's a Nissan Titan 2004 SE Crew cab 4x4.
I think it will be close. But with those tires and that big of a spacer you are giving up alot of wheel travel space. What width?? 12.50"?
I have a very great deal on 295/65/20 tires and i already have the 20 inch wheels.
Im shopping for 33 inch tires but it cost me the same price to buy a tires & wheels package on 17 inch than just buy tires for my 20 inch wheels. So i really need to know if i can fit the 295/65/20 (35 inch) tires , cause if they don't fit im gonna sell my wheels and buy a complete package on 17 inch.
Do somebody is riding 35 inch with a 2,5 leveling kit??
I an pretty sure you are going to touch at full lock against the back of the fenderwell.
sorry to chime in a little late here, but it depends on what wheels you are looking to run. There are several guys running 35's on stock wheels with just a leveling kit, some needed to do the PWM, but most are ok.
Pretty sure 35's will hit. I have the 33's BF Mud terrain on 20" rims and mine barely clear w/ a 2.5" Rancho extended shock. The 33's actually clear the rear of the front wheel well better before the leveling kit.
Interesting, I know of several guys running 315/70's and 35x12.50's on the 17" stock offroad wheels, and I know I could clear them. Maybe the offset is different on the stock 20's?
LT305/70R-18 Dick Cepek Radial F-C II E
My Truck - O6 CC 4xLE Loaded.
PRG 2.5 Mini-Lift
Ingen CAI
upRev
Flowmaster 50 Series
I am considerring Air Bags in the rear for towing. Any ideas?
I chose these tires after much much reading and considering what I will use them for. First and foremost I will mention how well they drive. A little louder than most AT's howerver, with the music on for all to enjoy - there is no noticable road hum or feel. Cornering is better than I anticipated but stopping you best leave more room. They have VERY similar specs to that of the BFG KO's but Cepeks are an 1" taller.
Minor Rub at a half wheel turn and at the bottom inside corner of the mud flap. This was quickly solved by driving for a few days including U-turns and Reverse. Then with a tin cutter, I cut off about 2 inches from the inside and about a 1/2 inch from the seem so the strength of the flap would not be badly compromised. That is it.
Dick Cepek's Radial F-C II On-/Off-Road All-Terrain
305/70R18 - 126/123Q E
Max Load: 3750 lbs
Max Inflation: 65 psi
Tread Depth: 20/32"
Tire Weight: 75lbs
Rim Width Range: 8-10"
Rim Measured: 9"
Section Width: 12.3"
Tread Width: 9.8"
Overall Diameter: 35.1"
Country of Origin "US" = UNITED STATES OF AMERICA
I tried to attach pic....
Can you post lots of photo's of your tires and truck. These are my next tires and i have asked few times if they rub.
PRG 2.5 Mini-Lift
Ingen CAI
upRev
Max Load: 3750 lbs
Tread Depth: 20/32"
Tire Weight: 75lbs
Rim Measured: 9"
Tread Width: 9.8"
I have an 05 with 33s x 11.50 and they fit just fine without scrubbing! My question is should I go with regular tires instead of these off road tires. I don't off road and now that I'm retired I don't drive in the snow!!
Really wish people would post the offsets on their rims when they post this awesome information.. thats what im trying to see, what offset rubs with 33s as apposed to 35s. I have 305/45/r22 right now that dont rub at all but i want knew wheels and tires but dont have the money for a lift right now. So if i go 2in keveling kit, and 20in rims with like a -12 or -24 offset, i should be good right? Especially with 33s but really want 35s. Go big or go home right?
1 - 20 of 20 Posts
