I have a 05 with thr 3.35 gear ratio, I noticed some howling coming from under while going down the road. I assumed it was the rear end on account of all the other failed nissans. A guy looked at it and said he thought it was the front axle and that the gear ratio was not thr same.
Turns out some previous owner put a 08 front axle under it, but it had the taller gears in it. 4x4 works, but it doesn't work correctly, as you can imagine.
I found a good front complete axle from an 2010 model. If the gears are the same, can I put it in without modifying anything?
