lol...not kidding. I'd normally think it was the Blower or VBC, but this one is new to me so I figured I'd ask the experts here...
AC and Heat don't work. BUT if I put it on HIGH only and then touch the door lock actuator, the Blower goes for about 5 seconds blowing hot or cold, whichever is selected. After 5 seconds it stops. It'll allow me to keep doing this but not trying to lock the door every 5 seconds I want AC in AZ!!
Also, the overdrive and manual shift option do not work.
I just got the truck and the previous owner was not very knowledgable but said it may be a problem with the alarm or stereo wiring.
Any ideas?
This could be a nightmare since no one knows what has been modified.
Wow good deal. How much did it set you back and what was involved in the fix?
The VBCM was $63 with tax from local dealer and literally went in in 2 minutes. Remove the 2 7/32 hex screws from under passenger dash. VCBM is attached to heater box / phlenum facing upwards. Pop off the 4 pin connector, replace and BOOM you're done.
