I ordered a set of highs 6K and lows 5K from HIDextra.com and I installed everything perfectly, but it is setting off my airbag light.... I am only using the ballast and not the harness, but I do not think that matters, does it? It happens when I use the high beams, usually right when I turn them on for the 3rd or 4th time. How can I fix this problem? I reset the light, but I do not want it to happen again.
Discussion Starter · #2 ·
I just installed the harness today and I will post once again if the light comes on... Any advice would be much appreciated.
Shouldn't. Did you remove the stereo by any chance. Doing so sets the light off..
Otherwise a fault with airbags?? Does light only come on when you turn on headlights?
