01SCSS said:
Been having power window issues. Anybody else? Have a fix?
I have had similar problems and have not seen anything on it yet.
I have a Titan SE Crew cab Smoke, power captains seats, RFS, yadda yadda.
I noticed that once in a while the drivers side window dosen't roll up when I activate the switch? Here I thought I was the only one. Like you stated, When I try it a time or two more it eventually works.... I just turned 1000 miles and don't believe mine are cemented closed by dust or debris....
I do not have my rain shields mounted yet....
I checked to make sure my window lock switch was not engaged....
This all started after I found out about and tried the neat little roll the window down with the key fob and key in the door tricks. I wonder if there is a conection?
Anyway, I will be interested in reading about this issue. I need to take mine to the dealer to get the radio head unit replaces to deal with the fade issue.
I'll mention it before I go and see if they can take a look. I'll report out when I get it back....
