1 - 9 of 9 Posts
· Registered
It sounds like it says in the fourm ( gets stuck in 3rd gear) But, after I get the truck going from a fill stop. It runs fine...so I wil give this recccomdation a try...
Thanks again!
· Registered
Thanks again!
Thanks again!
mine would drop from 5th to 1st yeah, but then i would cut it off then it would run fine till cooled off then do over, once i dropped pan and cleaned screen it was clogged from burnt fluid from pulling heavy loads changed fluid and lucas it did it a couple times but the lucas loosened up actuators and hasnt done it for 100,000 miles my son has it now 250,000 miles....good luck
· Registered
Hello Fellow Titan owners,
My AT check like check is on...my mechanic says I need a new transmission. Do I need to go to that extreme? Or anybody have any suggestions ?
Any mechanic that tells you a new transmission is need by only looking at a dash light is only looking to rip you off. Run from that place and never go back. Do not go to a Nissan dealer either. They will also lie to you and charge you a fortune. Bring your truck to a mechanic that specializes in foreign transmissions. Get recommendations from family and friends for a good honest mechanic. It may end up only costing you $600 in stead of $6000. Good Luck.
· Registered
For sure! Thanks ! I only have 160K on the odometer...so I find it hard to let the truck go!
1 - 9 of 9 Posts
