Went to open the back door, driver's side, and something went POP :( . Now the door handle just flaps in the wind. is it a huge job removing the inside panel to look at the mechanism inside or should I just go back to the dealer? Appreciate any insight available. Thx guys.
I would take it to the dealer. Just make sure you take some pictures prior to taking it in so you can prove any damage they might cause.
Yeah, probably the wise thing to do.
I went through this problem with my passenger front door and driver rear door. They replaced all the parts three times and the third was the charm. Only happens when the temps are 30 and below for me. If you start it up and let the heater run it would open normal. One trick if it happens is to cycle the locks a few times and it will at least close. I spoke to Nissan and they said they had never heard of the problem and it might be normal for the climate in michigan. I about fell off the chair when they told me this. Keep after them and make them replace everything.
