Super Moderator
I have a headrest monitor installed in a Nav pod and when i turn up the volume on the radio (Sony MEX-DV2000) the display on the monitor jumps around like a scratched DVD, but i have No DVD in the head unit. This has been going on well before i installed the L10's.
I have read it is a ground problem, the monitor is grounded to the stock radio ground wire, but the break pedal wire is grounded to the reinforcement bar that runs under the dash.
I have not tried moving the monitor ground wire to where the brake pedal wire is grounded. Should i try this before i buy this: http://www.cablestogo.com/product.a...le Base-_-Isloation Transformers-_-NA-_-41145
