i was looking at getting new battery terminals like this ones http://http://cgi.ebay.com/NEW-0-4-8-Ga-Pos-Neg-Digital-Car-Battery-Terminals-Set-/300492389086?_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D8657662307193556150 because i alrealy have a wire running from my foglights and my amp wire on the positve post and i will be adding a spal power window kit soon and i would assume that it get power right from the battery so i thought of getting those type of battery terminals so that i have more room to connect wires but do to our unique postive term. setup im not sure if there is one or how i would do it so what do the guys that have a few accso. hooked to the battery do to get around this or any suggestions would help
Discussion Starter · #2 ·
34 ppl looked and no one has any ideas? ok how is everyone else hooking up acc. to the battery? just using ring connectors
Bad link provided, as it has http twice. Loaded and failed, then I was able to back space in the new windows address bar, erase the extra http and load the page correctly. Here is a correct link:
http://cgi.ebay.com/NEW-0-4-8-Ga-Po...&otn=3&po=LVI&ps=63&clkid=8657662307193556150
I like that device! Yeah, most just use Ring Terminals, but a device like that should be superior. Just plan it all out in detail, so you know how it will all fit. One device I bought, but never used, is a 4 Relay Printed Circuit Board with Fuses Holder built in. Paid about $45 for it at Summitracing. I'll be finishing up my Electrical stuff this Spring/Summer. It's the one thing I'm a couple years behind on.
I'm not sure I would pay for a built in digital voltmeter, just due to doubts about durability of the DVM. But I see those on cars a lot, that have sound systems.
Our Titans will be fine with this, the newest Titans (2010+ ?) have a special sensor wire that is particular about Ground. But I do not know the facts of what it is or how it works.
i have my other stuff with just ring terminals and that what i planned on useing i just wasn't sure how many you could put on there before it became a problem with the windows it will be 3 i would use those battery posts but im not sure how to make them work with the setup we have on the postive terminal side
Yep, that is part of why I never finished up that part of my modding. It is the last major issue for me to do. I already added a large cable to power a 2400 Watt Invertor, but my setup is just not finished like I want. I'm going to reconsider a device like this, to help distribute better, I was just going to use a Terminal strip. I'll keep this thread in mind when I get it done. I'm going to add a 2nd battery too, since I have a spare Odyssey PC1700 sitting in front of me. Same mfg as my Diehard Platinum, same age too.
