Thinking about bedlining my bed caps and wondering what's the easiest way to remove it. I looked under it and it's got a whole bunch of clips holding it to the bed. Appreciate any help you guys may have.
Roy
I was told after I was rear ended by a semi by the body shop tech that they are use once items. He said once they are in place you gotta break'em to remove them. I cant really verify but that is what I was told.
Super Moderator
Use a set of pliers to squeeze the clips and slowly lift up on the cap, to much upward pressure will break the clips. They are not expensive from the dealer, around $40 per side, if you break to many clips.
You could also use double-sided tape on the areas that the clips are broken...just a thought.
ok, tried to take 'em off and along with clips there's also a bunch of double sided tape on there so I gotta think of another way. Maybe just tape around it and spray it.
