1 - 10 of 10 Posts
Do you mean a 110 VAC generator?
Adding any generator will be difficult - no room for it.
Hi Output Alternator, Additional Batteries and an Inverter may be an option.
What is your goal?
Your are thinking of a tractor with a PTO. I think it will be easier and cheaper to get a gasoline powered compressor.
Why not just add on an Electric Compressor as-is?? The Armada uses an electric compressor for the rear air suspension... AirBagIt.com sells some components...
i don't like the gas-powered compressors and i'm looking for more cfm than a 12v compressor can put out (i.e. airtools,etc)
Air Tanks can be mounted under the bed. :)
Discussion Starter · #10 ·
your tanks will only hold the psi that you compressor puts out but i think the warn compressor is what i was looking for, thanks for the info
1 - 10 of 10 Posts
