Does anyone have a link to a sight that has compared the myriad of drop in air filters available today? I have always purchased K&N Filters but I was never really aware until now their were so many new players out there. Any thoughts, experience, dyno results would be appreciated. Thanks in advance!
SHIFT_chicks-rule!
Can't wait to see where this one goes!!
I think, not for sure, that I'm gonna go with a foam filter in my Volant CAI. I know the K&N will probably give better performance results, but the foam should be better for the engine in the long run. I may run em both and get oil samples sent off to compare the two.
Hmmm, baja, TitanHauler......you might want to check out bobistheoilguy.com. There is a flow and filtration test on there and the foam filtered the worst between paper, cotton gauze (K&N) and foam. Here's the link; there may be more current tests elsewhere.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
In my own testing, the Fram Air Hog flows slightly more than the K&N. The Air Hog flowed the most with the least press drop, followed by K&N and lastly, the Nissan paper.
My test was done driving at WOT/6,000 rpm, as well as stationary at 3K, 4K and 5K rpm. I'm waiting for my Volant so I can test it, and then post the results.
JetTech has had oil analysis with the Volant, running Mob1 and had excellent lab results.
