new to the forum, sorry for another performance issue.
i just upgraded my travel trailer. went from 4500 lbs. to 8000 lbs.
i was considering an exhaust and cai, and also a biiger tranny resevoir.
any suggestions?
looking at magnaflow or gibson.....K&N or brute force.... and PML tranny tank
own a 2008 titan crew cab le short bed
Sponsor Burtman Industries has the PML transmission pan that is finned aluminum and adds 3 1/2 quarts. That should cool your trans pretty well.
Burtman Industries has the PML. Burtman is a sponsor and you should be able to find the link on this site. I am unaware of any other source. Burtman also has a PML extra capacity rear diff cover that should help cool the read diff, which seems to be of concern among this forum's members. These are rather inexpensive upgrades.
Aftermarket intakes and exhaust will increase the amount of sound your Titan produces. The drone produced by the exhaust and be intolerable to some. When pulling a trailer this can be exacerbated due to the sound reflected by the trailer, especially if you change the exhaust tip to point towards the rear.
That said, a cold air intake and muffler change will give you more horsepower. A simple muffler swap (instead of a cat-back system) is the least expensive way to go. The 18" Magnaflow 12258 will fit your Titan, but the 22" will produce less sound.
The PML pan is a good idea. The 2008 has a pretty good differential cover already but a bigger cover that allows for more fluid isn't a bad idea.
You should check to see if your Titan has the upgraded leaf spring shackles as the older ones are known to have problems. PRGProducts.com sells a nice, beefy set that also gives you the option to lower the rear a bit. But the upgraded Nissan shackles are less expensive.
