Hi Folks! I have a 2008 Titan and the other day I turned off the A/C and the fan wouldnt turn off. It blows out in the floor. When I turn the fan knob up/on the speed dont change but it will start blowing out the vents or what ever you have selected. The only way the fan stops is to turn off truck. Any Help with what part I need - Thanks!
Sounds like the blower control module is bad. The module in located on the bottom of the blower housing, under the dash on the passenger side.
i had a similar problem when i installed a new stereo. The truck went into some sort of logic lock. I unplugged the heater controls and then plugged it back it, fixed everything
