I seen this when I was putting my exhaust on tonight. My fluid level is fine but has anyone else had this problem? I'm at 39000 miles, anybody know a cheap or easy fix?
the way its corroding the undercoating you would think its brake fluid? I don't think gear lube would do that? IMOscr38 said:That is not a brake hose. It is the cable for the parking brake; there is no fluid in it to leak.
The oily substance looks like differential lube. Check your pinion seal and the axle seals for leaks. The oil has been slung onto the frame from somewhere, it is not a leak at that point.
Thanks, at least I can quit worrying about it. It was bugging the crap out of me all day.scr38 said:Looks like the transmission seal is leaking a little, but nothing to worry about at this point.
yeah, i'm going to. anybody got any idea on a cost for something like that? I haven't done anything like that before but if it isn't too hard, I'm sure I can do it, I've done all kinds of vehicle repairs.jhromy said:also looks like its the transmission seal to me, im sure its not a lot of fluid but i would still get it corrected
Should be, he said he has 39k. And one would think that this would be covered under the 60k Powertrain Warranty?!?!jhromy said:not under any type of warrenty any more?
That is what I thought of while I was laying in bed last night, but I wasn't sure so I was going to ask.54warrior said:Should be, he said he has 39k. And one would think that this would be covered under the 60k Powertrain Warranty?!?!
Did you ever find the leak? I just now have the same problem coming from oregon to Arizona.I too have a weird brake fluid loss problem. Mine happens every time I go to visit my parents for thanksgiving in Tennessee. For the last 2 years when I get into the Knoxville area I start smelling brake fluid. And sure enough it is in my left front wheelwell area and on top of the inner fender. I can never definatively tell where it is coming from. It almost looks like it is coming from under the metal block that has all the lines running to it which is located under the master cylinder. I top it off while there and intend to take it to the dealer when I get back home, then it stops leaking as mysteriously as it started. I know it is more hilly in Tn. and also a higher altitude. but for a year it does not leak until it gets back into Tn. maybe it is just alergic to Tn.
