The bully dog I installed came with a tool to measure, 1/4 mile times, 1/8 mile times, 0-60, horse power, torque, speed.
I was just wondering how accurate this tool is, the software is pretty cool.
It can be pretty accurate if it is adjusted right. If you have changed tire sizes then it's not right and has to be adjusted. If you have stock size 18" rims and tires, its probably withing a few tenths
Features
* Molded battery tray supports two ROAR-approved 1:10 scale size 7.4v LiPo battery packs with room for foam pads
* Receiver box, servo, and battery tray are removable in one piece for easy maintenance and cleaning
* Authentic, custom painted and finished scale licensed short course truck body
* Mounted and assembled scale wheels & tires with foam inserts and bead guards
* Functional full roll cage with integral dirt shields
* XP3D Computerized Digital 3-Channel FM Radio System with 10-model memory
* Powerful Pro.28 engine with slide carburetor and dual stage air filter
* Pro-Start hand-held starting system
* S2008 metal gear high-torque steering servo
* Hard-anodized shock bodies, 4mm shock shafts, and protective rubber boots
* Hard-anodized 3mm thick 7075 aluminum chassis
* Team Associated 2-chamber tuned muffler
* 3mm low-profile black anodized aluminum shock towers
* 3mm black anodized aluminum steering rack with ball-bearing steering system
* Sealed radio box with thread-through molded antenna mount
* Fuel bottle and glow igniter included
