Finally got them painted with bedliner and on the truck. Will take better pics later when the weather is better. How does it look?
i like em thought about getting some also
Well the Bedliner is like $7.50 a can and I used about 1-1/2 cans on mine. This stuff is not coming off and you can touch it up if ever needed. Kinda depends on what look you are going for.
From what I read here and at TT most prefer the Rustoleum brand and thats what I went with. I like the smaller texture it lays down. I just scuffed up each flare with a scrubber dubber pad, wiped clean with windex and then sprayed them lightly at first, then hit again until desired effect is reached. Good luck, and easy Mod for your T.
