Hey guys. I posted a thread a while back, my Service light was on and read I had a gross leak in the Evap. System. Nissan told me today it is a bad Canister Vent Control Valve. It's not covered under warranty of course, and not cheap. Any idea how easy this could be to replace myself?
Guess they didn't tell you exactly which valve-there are two: one called a purge control valve and the other a vent control solenoid.
The purge control valve is in the engine compartment, the vent control solenoid is is attached to the EVAP cannister next to the fuel tank.
There was a TSB published-which may or may not relate-but it does show a pretty good diagram of the suspects...
You didn't mention what year, so everything is on an '05.
Hope this helps a little...
Sorry, it's an '06 XE. I called Nissan after reading your post, they said they are one in the same, there are no longer 2.
okidokey---
good luck.
