Discussion Starter #2
I sprayed my engine off after washing my truck. Started just fine, went to pull out my driveway and it started hesitating, wouldn’t go past 2k rpms. I killed it, and it hasn’t started since. I pulled every plug, and harness possible, let it dry, hit it with electronic cleaner.
R
Pulled plugs
Replaced ipdm
Checked fuses
Swapped relays
New crank sensor
New battery
Obd scanner won’t register
Cut my key apart and glued to ignition cylinder, the chip is still good
Tried resetting
Discussion Starter #3
When key is turned to on, red truck with key light stays steady...
Sometimes truck will start and then immediately die
Fuel pump is good, yes I have gas,
I’m stumped and 90 miles from closest dealer
Hey Guys anybody ever figure this out? 2015 Titan doing the exzact same thing as shane described Every test has chked out!! except code reader wont read and fires off only when battery is almost dead but doesnt crank!!
