i have a 2005 and a 2007 titan le, the 05 has a good rear end with locker; the 07 had a bad rear end so i swapped them. Now the thing i have going is wiring it. I clippedha the wires at both ends. the tree feet of wire coming off the rear end i clipped has two plugs one black and one gray, that gray plug has a black wire and a white wire with a red line on it. and the black plug has a yellow wire and a purple wire.
The lock switch in the cab has 5 wires, one is brown, one is green, one is org, now the two that are left one is red with two blue lines; and the last one is red with two black lines.
Ok now does anyone know if there is anything between point a and b on the old truck i need and how to wire it. Thank you
