yes, I had same issue, replaced under warranty
yes, I had same issue, replaced under warrantyHello all,
I purchased a new 2022 Titan XD four weeks ago. Warmer weather has caused the engine clutch fan to engage more often than ordinary,,, doing its' job of course. However, it is extremely loud.... anyone else experience this?
Thoughts and insights appreciated.
Hi, I have a 2022 pro 4x xd Titan and the fan is ridiculously loud. Sounds like a semi! It pops on and off all the time hot or cold, humid or dry, rain or snow, AC on or off, low or high speed travel… I also hear the compressor kicking in, on and off-in 30 second intervals when the interior fan is on whether fan is set to auto or a speed setting regardless if the AC button is lit or not. Same goes with the defrost mode. I do notice the AC is working in all conditions because the windshield does defrost but it seems to be reduced when the exterior temp drops below 70f. Very confusing. The vehicle remains cool and all engine, transmission and oil temps are normal throughout the day. I run the vehicle all day and night and everything seems fine but the noise from the fan is very loud. I’ve spoken to other Titan owners at the super market who did not have an xd model and all claim to not have this problem. Even after showing them my xd fan screaming on idol they were shocked because they have never heard their own fan perform that way even when towing. Stopped worrying about it after my cousin who is a mechanic and my dealer both say it is normal for an XD because of the heavier weight and towing capacity the performance of the fan is required. So I guess I will just drive until their is a problem. Hope this helps you. Let me know what you think.Hello all,
Yup, its def stuck! Mine is so much more quiet now!Hi, I have a 2022 pro 4x xd Titan and the fan is ridiculously loud. Sounds like a semi! It pops on and off all the time hot or cold, humid or dry, rain or snow, AC on or off, low or high speed travel… I also hear the compressor kicking in, on and off-in 30 second intervals when the interior fan is on whether fan is set to auto or a speed setting regardless if the AC button is lit or not. Same goes with the defrost mode. I do notice the AC is working in all conditions because the windshield does defrost but it seems to be reduced when the exterior temp drops below 70f. Very confusing. The vehicle remains cool and all engine, transmission and oil temps are normal throughout the day. I run the vehicle all day and night and everything seems fine but the noise from the fan is very loud. I’ve spoken to other Titan owners at the super market who did not have an xd model and all claim to not have this problem. Even after showing them my xd fan screaming on idol they were shocked because they have never heard their own fan perform that way even when towing. Stopped worrying about it after my cousin who is a mechanic and my dealer both say it is normal for an XD because of the heavier weight and towing capacity the performance of the fan is required. So I guess I will just drive until their is a problem. Hope this helps you. Let me know what you think.
