It’s when I first start the engine, it’s not the injectors. I had a 2017 and had the engine replaced the cylinder was honed wrong causing piston skirt to slap in the bore. my new truck is doing the same thing.do you have an audio , the injectors are loud on our trucks, is it hot or cold .... or both ???
It worse in gear when a load is on it, you can hear it some after it warms upIt’s when I first start the engine, it’s not the injectors. I had a 2017 and had the engine replaced the cylinder was honed wrong causing piston skirt to slap in the bore. my new truck is doing the same thing.
did you ever get the issue resolved ?? and do you have an audio of it..
[/QUOT
still waiting for my appointment date July 11thdid you ever get the issue resolved ?? and do you have an audio of it..
I don’t know how to attach the recording if you could direct me on this I can post it. Thank youstill waiting for my appointment date July 11th
Glad to read something is moving on it. Thanks for the update.I don’t know how to attach the recording if you could direct me on this I can post it. Thank you
thanks I just want my baby fixedGlad to read something is moving on it. Thanks for the update.
