sounds like you are in limp mode
reset your computer ECM look it up several differant posts on that got one on utube also disconnect battery? not sure on that one, try it why not? got to go Blue Angles in town!
1122 is Electronic Throttle Function; 0102 is Mass Air Flow sensor circuit; 1124 is Electronic Throttle Motor Power.
You have a fuse or fuses blown or problems with wiring to the throttle control and/or MAF sensor.
Thank you for your reply,all fuses good,do you know which relay controls the throttle motor? i have a feeling thats the problem.
Did you check fuse #52, a 20 amp, located in the IPDM?
The throttle motor relay is internal in the IPDM. It is not one of the plug in relays that you see when the cover is removed.
