The Service Engine Soon Light came on and the code is P1168 which is supposed a failed heated oxygen sensor (bank 2, sensor 1). Can anyone tell me where this sensor is located so I can replace it.
Thanks
This code indicates that there is a problem with the wiring, connectors, or the A/F sensor has failed. That sensor is in the exhaust manifold on the passenger side. This is not the O2 sensor, which is located in the B pipe.
The A/F sensor is item #1 in the attached drawing.
This code indicates that there is a problem with the wiring, connectors, or the A/F sensor has failed. That sensor is in the exhaust manifold on the passenger side. This is not the Oxygen sensor, which is located in the B pipe.
whew.... im relieved i found a guide in here. i will just scan this so i can have a copy of it in my garage. i will just be uploading some step by step procedure to help others about this concern. thanks again. im gonna give search button a kudos lol:love-blow-big:
