· Registered
So it's cold and windy today up in the great Northwest, no better time than to spend a little time sprucing up the old Titan! One thing that has been driving me crazy for a while is the iron on "Titan" embroidered patch on my floor mats, the corners are peeling up! Here is a picture of the passenger side, but the drivers side was even worse as it obviously gets the most wear and tear.
I finally figured out a good method for repairing this problem that works pretty darn well if you ask me!
What you need:
Permatex 118DA Spray adhesive
Plastic Sandwich Bag
Toothpick
Household Iron
Simply spray a little adhesive on to the plastic bag and roll your toothpick in it. Then apply a small amount to the underside of the label and to the mat.
Make sure the iron is hot, I set mine to high. Drag the iron over the glued area for a minute or so and allow to dry for 30 minutes. When your done you label should be affixed better than new!
Hope this helps someone!!
Enjoy!
· Premium Member
nice job, I would have probably tried fabric glue but I bet your repair lasts longer.
· Registered
Fabric glue is a good idea too, but honestly I think thats about all the permatex spray adhesive is in reality.....LOL. I think the trick is the heat applied by the iron, that really seems to bond the two surfaces real well.
· Registered
A hot glue gun with some carpet glue works well also and just apply some weight till it sets up a matter of minutes. Nice post!
· Registered
I never like placing something heavy on an attempted glue repair, inevitably glue oozes out and sticks to the object supplying the weight.
· Registered
Well the solution is to not over do the glue. As the commercial says, " a little dab will do ya"
