We've had our Titan for a couple months now...its an 08' LE CC 4x4 w/53k...so just to be on the safe side, going to change everything over to Royal Purple. Figured its worth the extra now since we use 4-wheel drive alot and do alot of towing.
Theres just one issue....the front pinion seal is leaking. Is this a common problem? Before the Titan I had a 00' Z28 and the fractory 10bolt's were notorious for the pinion bearings wearing and causing the seals to leak and it wasnt an easy fix due to the crush sleeve.
So....
Is there something like a crush sleeve that makes this more than a simple fix?
What does the nut torgue to?
Thanks guys.
