1 - 17 of 17 Posts
Has anyone modded the factory fog lights so they can be turned on independently of the headlights?
Search had way too many irrelevant results.
Yes they can!
Search the forums a little harder... there are a few ways to do it.
-ern
SHIFT_CT's_"Screech"
BaseballFanz has done this mod. He installed a relay inside of the turn signal stock. Might want to send him a PM.
<<<-------- kinda surprised BBF hasn't chimed in yet... he's usually on top of it!
Yeah, I got mine done by wakeboarder2186 (ex-member here). You should be able to find a howto writeup on it. Good luck!!
Jeremy, don't you just have the jumper mod so that you can turn your fogs on with your running (amber) lights? I think he is talking about the foglights being completely independent so that he can turn them on whenever he wants.
ah ha... you're right nick :).
my truck doesnt have running lights... i only have the headlights that come on automatically in the dark.
Parking lights/Running lights/Amber lights. When you're amber turn signals are on. That's what I was referring to.
got ya ..
your name is nick too?
with a pro 4 x?
black?
haha. what are the odds? is yours a long bed though, or is it just the angle of the camera in your avatar?
short bed..
my girlfriend likes you already haha
well if you want to run it on you its own switch then you should run it through a relay. cause you could just run them with an inline fuse to a switch but to be safe and to make sure not to mess anything up just run a relay. It is pretty simple to do there will be instructions with the relay telling you witch prong is for what and if you wire it as it say it will work out just fine. the hardest part is finding out where you want to mount the switch. If you have a local electrical shop then I'm sure they would be more than happy to help you out with figuring out what you need and how the relay works. Good luck I might be able to help you out through messaging to when it comes to wiring it up if you need it.
Post pics after if you do it.
Discussion Starter #14
I have no problem wiring the relay- I was hoping to use the factory switch on the stalk. I'll have to dig up a wiring diagram and see if this is possible.
I have the jumper in the fuse box from MiseryTom. When the amber parking lights are on, so are my fogs. I'd have to track him down and see if he could still make them.
smithy wesson: send baseballfanz a pm. He did this so that you can use the switch independently and turn the fog lights on whenever you want. It's much easier than having a separate switch.
PRO_4_X said:
short bed..
Haha. Would she happen to have a close friend or sister? Haha
1 - 17 of 17 Posts
