So I purchased this lift on the good word from this and other forums. Got the package on time. Opened it to find no instructions. No big deal...I'm pretty mechanically adept at stuff. I found that Performance Lifts.com had it on their webpage in PDF so I downloaded it anyway. Next issue, I opened the box. The bumpstops look good. Came with lock nuts. Then I checked the actual spacers. The nuts provided with the spacers dont tighten further then one turn. I grabbed a wrench figuring it was some burs on the nut but as I tightened I noticed it was cutting into the thread on the mounting bolt. WTF?! So I thought hmm maybe its just one. Nope. EVERY SINGLE NUT was the same. It appears from what I can see that the thread pitch is off or its a VERY poorly made nut. So I went into my tool box and grabbed a handful of standard nissan 14 MM pitch nuts that I have..(I've owned 5 straight Nissans in 3 years ALL that I modified so I have tons of Nissan sized crap EVERYWHERE) anyways I threaded those on and amazingly they tightened all the way down to the bottom. All this crap and I haven't even installed it yet. My next gripe of course is that there are no lock washers provided on the spacer studs. With something that is going to be under as much stress as this spacer and the constant vibration of the fron suspension under compression (even more so Off-Road which I assume this kit was designed for) the chances for this nut backing off are pretty good. Unfortunately I dont have any lock washers that size so tomorrow before I install it I have to go get some. Somehow I don't see how this was work the extra $50-75 I spent over the Daystar, CST, Skyjacker, etc lift level kits. Either way I am NOT happy. Stay tuned to see if the install goes according to plan.
