I was driving on the freeway today and all of a suddent all the lights went out on my cluster, temp and oil gauges dropped, RPMs and Speedo dropped to 0 and the "Brake", "VDC off" and "SLIP" light came on.
The turn signals work but do not tick or flash on the dash and the cruise control doesnt work but other than that the truck seems to be running fine.
Any help is greatly appreciated
Edwin
what year is your truck? have you had the ECU recall done to it?
there is an recall on the IPDM, there are plenty of threads on here about this issue and most of the symptoms you describe lead to it. but this has mostly been an issue with early model Titans. but some new models as well. do some research. check your VIN with Nissan to see if your truck is up for the recall. also search the threads for any info on what the IPDM does....where it is....blah blah blah......its an easy fix, shouldn't take a dealer long at all.
