1 - 9 of 9 Posts
Hi CT, i want to start by saying im a new member here bcause i just became a proud owner of an 04 cc. but anyhow.... im having a slight issue with my gauges. on a cold start all my gauges in my cluster start chattering for about 15 sec. then go to normal? the only thing i can think of is maybe a weak battery? was woundering if anybody has ever encountered this problem before, or had any greatly appreciated advise. thanks, John
mine only chatter exactly 1min after i turn the truck off(recalibration of the cluster). sounds like that batt is def possibility. take it to autozone and get it checked out. cold starts take a lot of juice.
no prob...check the cables and make sure they are tight and not corroded. seen this issue several times. usually results in a new batt
just noticed last night for the first time ( sittin in my truck after it was off my rpm gauge went up t0 like 500 and my rpm went between 500 and 1000.. i was a lil weirded out haha
1 - 9 of 9 Posts
