Both of my heated seats just stopped working. I checked the fuse and its good. Does anyone know where the relay is and how is it listed. I checked under the hood and didn't see anything labeled for the heated seats. Can someone help me out?
There is no relay. Does the light come on when you turn on the switch? If so, the fuse is OK. Fuse is #16, a 10 amp, in the inside fuse block.
If the light comes on but no heat, then the thermostat, the heating element or the connecting wiring is bad.
both lights in the swtiches come on, but no heat in either seat.
