I use a cooling system tester to force the air out through the overflow. Another way is to jack up the front end or use ramps to get the radiator cap as the highest point, remove the cap, start the truck and get it hot, rev the engine at different speeds for about 10 minutes and it should bleed out. If you plan to do the cvs bypass check, you can use a t-fitting with a cap such as the one Preston has in their kit. No need to raise the truck. Remove the hoses from the cvs and connect them with the t-fitting, run the engine to temp with the cap loosened. You’ll have to play with how loose as the air bleeds out. The entire hose should get hot with the engine. If the air is in the heater core, it will take awhile. Rev the engine a few times during the process. Be aware, this can get a bit messy, but it works.
