OK, I have been a Titan owner for 4 years, I just found this site. Some of you guys know what you are talking about. I need some help, I got into my truck today and the emergency brake light is on but the brake is not set. I cant get the light to go off, any ideas.
Check you master cylinder for fluid level. If its low, add fluid and pump brakes, light should go off. If not, check condition of rear pads.
i had the light problum on mine all i did was put some break fluid and it went way :)
BTW welcom to clubtitan
I put fluid in that did it, thanks. I also have a SES light, I took it to Autozone they said the code came back as U1000. They had never seen that before. Anybody have any ideas?
Take it to the dealer and let them find the bad ground. U1000 means that the computers can not talk to each other and it is caused by a lose ground some where. If you still have warranty I would say let the dealer check it out to make sure its all good.
here is a link too
http://www.clubtitan.org/forums/showthread.php?p=687725
