Ok guys I need a little advice/help here. My back (tailgate) window stopped working about a year ago. Thank goodness when it stopped working it was in the up/closed position. When I hit the switch to lower the window, I can hear the relay clicking but the window will not move. Should I assume the motor is bad and need replacing? Has anyone experienced this problem before?
:scheibe-big::scheibe-big:
Windows on these trucks suck. My driver side window started to turn..needed to bang the door to get it to move, and had to help pull it up. Now it doesn't work at all. My passanger side is now starting to fail (getting weak).
I could use some clues too..
BUMP to bring this thread back to life. Help from other members much appreciated.
