· Premium Member
It could be several things. The first thing to do is check your brake fluid level. It must be filled to the full line.
· Premium Member
Those are the the 2 most common causes, either low brake fluid, or bad wheel sensor. The only way to pinpoint which sensor is bad is to hook up to consult II at dealer.
