Just busted my drivers side. Fixing to go buy a new one, but I'm not 100% on how to remove the old one. Unbolting it from the transfer case is simple enough, but what about the other end?
thanks PP
Discussion Starter · #2 ·
well that was easy enough. A person could do it in 30 minutes, taking their time! Dealership wanted $290.00 just to install it!
Remove the wheel, Remove the cotter pin, remove the 32mm nut. Then remove the 6 14mm bolts that hold the axle to the transfercase. Use a mallet to drive the axle out of the hub. Now install the new one. Boda-boom boda-bing all done!
Um, isn't there supposed to be a c-clip attached to the end of the axle inside the differential?
