1 - 15 of 15 Posts
alohaarg said:
guys i have two marks one for cold one for warn, i read the manual and i still no understanding how it works.
The cold mark is where the line should be if the truck has not been run for a while and the engine is cold. If the engine has been running and is warm the line should be up to the Warm mark.
Check it with the engine running. If the engine was cold before you started it, use the cold mark. If the truck has been driven so that all temps are up to normal, use the warm mark. Also, when checking the fluid, rotate the stick 180 degrees before inserting it. In other words, remove the screw holding the stick, pull out the dipstick, wipe the fluid off the stick with a clean paper towell, and reinsert the stick so the tab for the screw is on the other side from the tab on the dip stick tube. You must do this to get a accurate reading. After checking the level insert the stick in it's proper position and replace the screw.
most do it in park, but neutral will work
I'm confused...do I have this right?
The notches are for checking the fluid level when cold? The level should be at the top notch.
The hash marks are used when the fluid is hot? The level should be at the top of the hash marks.
I was told you check the fluid while it is in "D"
Look at attachment.
Sure you didn't read that on someone's tombstone? J/K :)
Always in Park, on Level Ground; Warmed up is best. As is having the Parking brake on. But absolutely never in Drive.
1 - 15 of 15 Posts
