1 - 2 of 2 Posts
Hello, Titan lovers.
We belong to the Armada Forum, but seek help here.
We've a 2010 Armada Platinum with a dual climate control issue. The vents seem to default or stay on the defrost and/or floor, and no heat. At a great cost, the Nissan dealership replaced the defrost mode door actuator. This hadn't solved the issue and they suggested replacing the heater control valve under the hood on firewall and the entire HVAC air box etc. for $3000.
We're not able to perform the system self analysis as can be entered on the 2011 Armada (turn ignition on, stereo off, then press setting for 5 seconds).
Any/all help appreciated.
Thank you
Your issue sounds similar to mine except I had warm and cold function remaining. My vent direction was stuck on floor/defrost. Search “blend door actuator” here and Titantalk.com and YouTube.
My cost was $50 and 3 hours of my time.
1 - 2 of 2 Posts
