:x i was driving on the hway and a light and sound came on in my dash board, i thought it was one of the tire that might have low pressure and the sensor was telling me that but it was not. the truck kept str8 i did not feel nothing wrong more that some wird noise and when i stoped to take a look at i could not believe how bad the tire was.
Did you guys hear about any problems with the tires? maybe it was just bad luck, but what is funny the night before to the blow out i check all tires presure witha a new device i bought and i put all them to 35 psi, my meter read 35 psi and the gas station meter read 39 psi so i falow mine cause it looks like a clock and it is easy to read. My wife says i over inflate the tires by using that new divice but i explained to her that even if my metter did not work acuraly in the worth of the case i did no put more that 40 psi cause the gas station metter read around that figure. the tire says to use no more than 44 psi so i think i have to be ok.
now i put the replacement tire and after driving the truck for a while the tire pressure light still on i check the pressure of the tire and is fine(35psi) so i dont really know what still wrong
any idea?
Thanks
any idea?
Thanks
