I am installing some illuminated door sills that id like to come on when you open the door and turn off when you close the door. Does anyone know of a wire that I can tap into that would make this work?
Nissan sells a accessory connector that plugs in at the front left and right kick panels that supply ground, 12v, ignition power etcI am installing some illuminated door sills that id like to come on when you open the door and turn off when you close the door. Does anyone know of a wire that I can tap into that would make this work?
Yes. And I apologize I just saw you have a 2008Is this only for 2nd Gen Titans?
No worries mateYes. And I apologize I just saw you have a 2008
