IM A NEW MEMBER I HAVE HAD MY TITAN CREW CAB FOR ALMOST A YEAR I GOT MINE AS SOON AS IT CAME OUT MY QUESTION IS THE SLIP AND BRAKE AND SOME OTHER LIGHT IS ON CONSTANTLY IM GOING TO GET IT CHECKED UNDER WARRANTY BUT I DID NOT KNOW IF ANYONE ELSE HAS THIS ISSUE :wink:
I had that problem on my first Titan. It turned out to be a faulty brake release switch. With those lights on it's storing a code, the dealer will easily be able to extract the code and fix the problem.
Keep in mind though with these lights on you don't have a correctly functioning ABLS nor ABS system, so make sure to keep a little extra distance between you and the person in front of you in case you have to jam on the brakes.
Good luck and let us know how it all turns out!!
THANK YOU I HAVE NOTICED THAT AND ALSO THE SPIN CONTROL ON THE WHEELS IS OFF THANK YOU SO MUC HAVE A GREAT DAY...
the 4 low light kept coming on on mine, the dealer had it two times and fixed it on second visit
thank you brother im taking it this weekend
