Here's a pic I've attached to show the 4 bolts on each side of the frame to loosen in order to adjust your front bumper. Mine was 1/2" uneven and by doing this procedure I was able to get it within 1/16". Not bad when you consider the holes are not slotted. There's just enough slop when the 4 bolts on each side are loosened to make the adjustment.
You'll need a floor jack, or someone else to hold the bumper into position while you tighten it. Also you'll need a 17mm socket for the 2 bolts going through the frame on each side and a 12mm socket for the side brace bolts.
Procedure:
Loosen all 8 bolts about 2 turns or until the washers spin freely under the head of the frame bolts.
If your alone use a floor jack with a block of wood on it to lift and hold the bumper in place while you tighten each side evenly. Measure before and after to get an idea if you got it even.
That's it, you don't have to remove your skid plate or splash pan to do this. Takes about 10 minutes.
Dale
Procedure:
Dale
