1 - 20 of 20 Posts
I lost my key fob and need a replacement. Whats the best/cheapest route to get a new one. Goto the dealer or buy one on ebay. If i buy one on ebay how do you program it. Do you need to bring it to the dealer anyway to program. Any help is appreciated. Thanks Fellas!
I think the best way to get a new key fob would be ebay, thats what I did and did the programming myself. If you follow the instructions below you should have no problems doing it yourself, good luck.
ID CODE ENTRY PRODCEDURE
Step 1) Sit in drivers seat, close and lock all doors.
Step 2) Insert key into and remove it from ignition key cylinder more than six times within 10 seconds.
(Hazard warning lamps will then flash twice).
NOTE:
Withdraw key completely from ignition key cylinder each time.
If procedure is performed too fast, system will not enter registration mode.
Step 3) Insert key into ignition key cylinder and turn to ACC position.
Step 4) Push any button on remote controller once. (Hazard warning lamps will then flash twice).
At this time, the oldest ID code is erased and the new ID code is entered.
Step 5) Do you want to enter any additional remote controller ID codes?
A maximum of four ID codes may be entered. If more then four ID codes are entered,
the oldest ID code will be erased.
If you do not want to enter any additional remote controller ID codes, go to Step 9).
Step 6) ADDITIONAL ID CODE ENTRY
Lock all doors with LH (driver side) lock/unlock switch
(in main power window and door lock/unlock switch).
Step 7) Push any button twice on remote controller once, (Hazard warning lamps will then flash twice).
Step 8) Do you want to enter any additional remote controller ID codes?
If so, unlock doors then repeat Step 6) and Step 7).
Step 9) When complete, open door, and check operation of remote.
Is it me, or is this about as clear as mud??? LOL I am confused!
I purchased a Titan key fob from Ebay and programmed it in minutes.
I found a key fob on the ground for an Armada at the gas station (it was lying in front of a pump).
I managed to program it the same way as I did to the Ebay fob to work with the Titan. The trunk-release button activates the alarm.
Look at this procedure for programming the fob. I had to make it into two pages due to the size, but you can see how the process continues on the second page.
Makes me wish I'd kept my extra fob for my old truck....they never asked but I gave it to them anyway:(
I didn't know it was that easy. My dealership wanted over $100 for one. Luckily, mine still works with my strategically placed rubber band. :D
SHIFT_Mr. Quick Answers
kha4079 said:
what about a new key for our trucks.... where do i get one and program it for my titan?
A new key with built in transponder need to be program by the dealer or some independent locksmith can do it also if they have the right equipment. When getting a key program, bring all keys with you as they all need t obe reprogrammed at the same time. Non transponder key don't need to be programmed.
https://www.streetkeys.com/
KenmoreTitan said:
Perrty really? Do you have a pic? I would love to upgrade from the generic looking stock ones.
Here it is. I was told by the dealer that they didnt think it would work but they had never tried it. I dont want to fork out the $$ for it if it doesnt work. also they have a tiny key inside also incase the batterys die.
Car Keys Solution Melbourne provides good Duplicate Car Keys Services in Melbourne.
Car Keys Solution Melbourne is here to help you with this problem. If you have lost your car keys and looking for duplicate car keys in Melbourne, we deliver the best identical car keys at low prices. We have experienced, certified, and qualified experts in our teams who have exceptional skills and follow specialized professional attitudes towards their work.
1 - 20 of 20 Posts
