i am hearing a knocking noise on the driver side when i am driving slow. its not a loud knocking but when i put it in 4 wheel high the noise is very loud. has anyone experienced this and if so what was the issue.
You have a bad CV joint, or the half shaft has slipped out of the front differential. This is a fairly common problem.
If it is the half shaft it may be possible to push it back into place. If there is damage inside the differential then it may need to be replaced, which will be expensive.
If you have a bad CV joint it could also be an expensive fix.
