1 - 2 of 2 Posts
Anyone tell me which of the 5 MAF sensor wires in the connector plug run to the IAT sensor in a 2005 SE gas Titan?? If got a empty terminal, brown, black, white, red & black wires as you go left to right with the connector plug attached.
Thanks in advance for helping a newbie.
I do not know which wire it is, but must ask why it is of importance? What problem are you having?
You aren't considering Modifying it for performance enhancement are you? Do not use any kind of E-Bay Chip/Resistor to try to gain HP or MPG, they are not safe at all. They trick the MAF and throw off your true AFR, which can cause catastrophic engine failure.
1 - 2 of 2 Posts
